Stop / start stopped working ??
39K views 17 replies 12 participants last post by  gorge
#1 ·
Hiya Guys. Anybody experienced there Stop/Start not working. The last couple of days i've noticed my Stop/start hasen't worked when it should. Done plenty of various driving / mileage stints this weekend and the system hasen't worked once ?? No warning lights or anything to say there's a fault. Might have to ring VX in the morning.
#9 ·
I had same problem today on my 1.3cdti. Went thru all of the troubleshooting both on here and in manual - zip. In the end I did a deliberate stall to force a clutch down restart - and it started working again immediately! Absolutely no ideas why this happened tho, but it seemed to be affected initially by first activation of demist.
#15 ·
FirestoneDK said:
Johny555 said:
Battery should be charging,14.5 volts when engines running,
The Corsa haves some intelligent charging. Mines charging with 14,7-14,8V and when the intelligent charging senses the battery is fully charged, it only float charges with 13,6V
Correct. I have had 15.0V, and after a long run it can drop again to 12.5V non-charge mode, have found. Those plug in voltmeters are handy to watch out for under charging.
