1 - 7 of 7 Posts
Does anyone know how to remove the plastic panel inside the boot lid?
I have a 2019 Corsa E 1.4T 5-door. Something is lose inside the boot lid, I notice it when I open/close it or wiggle it up and down, there's a nut or bolt or something rattling around and it's irritating, car is brand new.
If it new take it back to dealer to fix.
You can take the panel off by removing the two screws from the panel and popping the clips which hold it on. You can break these clips if your not careful so personally I would call the dealer and explain. They should sort it
Probably the same as on Corsa D?
Another way could be to remove the rear fog and reverse lights and reach inside the boot that way.
I have a pretty long drive to the dealer so I thought I fix this myself.
Klesmy said:
Take care when taking out the light. I've taken mine off to change bulb and not an easy job
I tried this but damn that was hard, I removed the bolt and then pulled it to the side but those hooks wouldn't release from the bootlid edge. I was afraid to damage something, what is the trick to remove it?
1 - 7 of 7 Posts
