I am a driving instructor with secondary pedals. Sometimes with no passenger in the car when you press the brake the car brakes and then it feels like someone else has pressed the brake on the passenger side? Any thoughts?
that’s a strange thing to happen, do you notice if the brake pedal drops on the passenger side when you press the driver side brakes? If it does it will be the duals causing the issue and best to call the He-Man dude (harry if it’s in Scotland) if not it’s most likely the car causing the issue
Sorry only just seen your reply. Now also having the clutch pedal stick half way down sometimes- have to lift it with toes and then fine for a while. Thinking related?
Have an intermittent issue when driving When depressing clutch pedal sometimes goes soft and I am unable to either get out of gear on in gear. Does the Corsa have a hydraulic clutch system Looking around on internet not giving me much help apart from clutch spring which I don't think it is
Hopefully someone can help - Thanks in Advance. My daughter has a 2015 1.2 Limited Edition with approximately 29K miles. After a recent long weekend away without the car and it not being used over that period. The first time she attempted the to drive the car, she immediately new that there...
