1 - 3 of 3 Posts
Hi so today I was driving then I stopped at the lights and when I went to put it in to first gear it would not go in, and the clutch was stuck right down to the floor. I had to put my foot under it to lift it back up then it was fine but it seems really soft and low and I have to lift it up sometimes for the cruise control to work. Can anyone help thanks
Super Moderator
It will probably be either the slave cylinder ot pedal spring, the former is a box out job the latter is an expensive fix but you can save a lot of cash if use a spring attached to the pedal and hook it onto something above under the trim panel.
Super Moderator
Found the fix in another forum
1 - 3 of 3 Posts
