1 - 20 of 24 Posts
Hi all I have taken out the compressor and tyre seal and replaced with a spare wheel. Does anyone know if the compressor can be used with out the sealant to simply blow tyres up
Yes you can use the compressor with out the sealant to inflate tyres I've tried it myself
Thanks both. Gonna put it in the car then with the spare wheel.
joeboy said:
I have a ring rac 630 in my right hand side compartment in the boot.
Fits in perfectly.
The LEs compressor and sealant are in the side compartments, usually already connected to power too.
is it a space saver? if so where did you source it and does your boot floor carpet thing have reinforced underside?
Discussion Starter · #9 ·
Got genuine Vauxhall steel rim and a tyre for 60 delivered from tyreleader.co.uk all I had to do was have the tyre fitted to the rim which when I spoke to my regular garage they did for nothing!
Discussion Starter · #10 ·
It's a 15" rim and I just got a larger tyre. Fits in the spare wheel well fine no problems.
The 60 was wheel and tyre delivered from Germany!!!!
A quick heads up after I paid the bank rang to check because the are based in Germany and it looked like fraud but I got the wheel and tyre within 4 days
LimeyUK said:
Fits in perfectly.
This is what I thought too but apparently some do, whilst others dont and have theirs under the boot carpet like other specs, I think Anthony said his LE had the kit and compressor under the boot floor.
LimeyUK said:
Fits in perfectly.
yep mine was under the carpet. And I have a LE
Huh, that's strange - do you have anything that uses the sides?
Why would some have it in the side and some not?
The sides in my boot just have electric looms running through them and everything else is under the carpet
I assume you can remove the compressor itself, but it is just wired in.
It's a Vauxhall, these odd differences for no real reason are a common Vauxhall idiosyncrasie that has gone on for years. :lol:
Discussion Starter · #18 ·
Mine is now satin the spare wheel with other tools. The sides of the boot have nothing in and are too small to fit much in
1 - 20 of 24 Posts
