1 - 4 of 4 Posts
Had to fill up my screenwash tank this morning, whilst doing so I checked the rest of the levels and noticed the coolant level was a good inch below the maximum mark, the car has only done 8000 miles, should it go down that much so quickly or is it possible theres a slight leak somewhere?
It's probably pressure related.
Besides an inch in 8000 miles is not quick, not even close to quick.
You'd know if there's a leak because there would be a light mark on the ground where you park the car.
how close to max was it to start with? Normal fill level is just above min when cold. It is capable of holding that steady over 8000 miles. My D wasnt topped up in 21000.
But worry is do you not check it every week??
1 - 4 of 4 Posts
