1 - 5 of 5 Posts
Hi.
I'm having kind of a problem with the gearbox in my car.
When the car is up in speed, and i pull the gear lever too slow out of 4th gear, i can hear that the gears are grinding in the box.
If i pull the lever a bit faster, then theres nothing.
Also, sometimes it can be hard to put in reverse, i have to use some force.
Should i contact my dealer about this, or is it normal?
This is my very first car, so i dont have much experience with cars.
Is it consistent? And the clutch is always to the floor when you're trying this right?
What about when you're stationary, does it happen then?
Yes, it is consistent. And yes, the clutch is always pressed to the floor.
There's nothing when the car is not moving.
Not noticed that my self but I do sometimes have problems getting into reverse from first Start up.
1 - 5 of 5 Posts
