Just recently purchased a Vauxhall Corsa Griffin 2019 (only had 2 weeks) which has a rattling noise coming from the dashboard/windscreen area, also have noticed the Scuttle Panel has come away from the main windscreen.
It looks very much like the rattling noise is coming from the loose Scuttle Panel.
Apparently there are supposed to be some clips holding the Panel in place under the bonnet but on mine there isn't any just a load of debris and leaves??
You can push the Rubber Seal again the Scuttle Panel and it will move back into place flush against the bottom of the windscreen where it should be but of course when you drive the car the vibrations cause the Scuttle Panel to Drop Down again leaving a Gap between the Panel and the Windscreen yet again allowing water and debris back in, surely this isn't right.
Has anyone else had this issue and what was the outcome.
