1 - 6 of 6 Posts
I have a petrol Corsa 1.4se on a 62 plate and have suddenly noticed that the engine management light comes on now and again and the car is sluggish when going through the gears. I've taken it to a small garage and he thinks it's a faulty ECU but needs a second opinion from an electrician while I'm guessing will be able to diagnose correctly at a cost of £50. The garage has ruled out fuel filter/pump and coil issues and is saying that I'm losing a little compression because of faulty unit.
My question is has anybody had the same problem and if so did they replace the unit with a second hand one
The car only has 38k on the clock
Cheers
Mine was the coil pack + new set plugs , 26,000
1 - 6 of 6 Posts
