OK guys, my SRi has a visible exhaust tail pipe but its not chrome like it was on Corsa D SXi/SRi models just mild steel, however the brochure for the E has a section on accessories and there's a bit about VXR styling accessories like the VXR styling kit stuff like the side skirts, rear roof spoiler and the front and rear bumper skirts which can be added to any Corsa as an accessory, but also lists a chrome exhaust tail pipe as a VXR styling accessory, now obviously all those things are standard on there Limited Edition/SRi VX-Line, but I always just assumed it was the same as the D, you couldn't buy the chrome tip for the exhaust separely,you had to buy the full back box as the chrome tip was welded on to the mild steel tip, and that if you had a Life/SE/Club/Excite spec D and wanted the VXR styling kit you simply ordered the one with the rest skirt for cars with hidden exhaust tip, however some googling has turned this up:
http://www.vauxhall-accessories.com/corsa-e-exhaust-tip
Now I'm just wondering if this is the same tip as fitted to Limited Edition/SRi VX-Line (my exhaust is the exact same, same style and shape etc minus chrome tip) as I presume if this part is now available separately from the exhaust it must either just push on to the mild steel tip or clamp round it where I thought like the D the tip would be spot welded on at the top and bottom to the mild steel tip, could someone with a Limited Edition/SRi VX-Line check if your chrome tip is is spot welded to the mild steel one (its usually a weld at the bottom in the middle of the chrome tip and a weld at the top edge of the tip)
I want to order the part in the link, but only if its identical to the factory fitted one and fits the same as the Limited Edition/SRi Vx-Line one, which I assume it must be with a Vauxhall part number, on a genuine Vauxhall parts website.
Cheers
Cheers
