1 - 9 of 9 Posts
Does any Corsa E come with front footwell lighting, like what the early spec Corsa D's had, basically like a boot light but in the plastic sill trim shining into the footwells? I remember my father in laws old 08 plate Corsa D having them, and was sure I read something about foot well lights making a comeback in the E, but now can't find any reference to them and my SRi doesn't have them despite having ambient lights pack.
G
no footwell light in any of the E`s, only the ambient lighting. Not sure if the E`s have the hole under the dash for the light to be fitted like the D`s had.
I'm also really curious about this, I have the Corsa e VXR which has the ambient lighting, but it would look really nice with some soft glow red LEDs in the footwell too! I will need to check if there is the holes for it
I fitted these red Led footwell lights. They simply plug into the cigarette lighter and since i don't really use it, its not a problem. There is also a on/off switch which I positioned discretely. No wires can be seen at all as I fed the lights through a hole under the centre console.
Where about did you get the limited edition mats from?
Has anyone pulled the trims off to see if the wiring and socket is present like with Corsa D? I'll have a look at ours at the weekend if not.
1 - 9 of 9 Posts
