After turning off the ignition I noticed that water or fluid was coming from underneath the the car by the front seat area in the middle not sure if it's from the air con unit..... It does this for about a minute then stops
If it's by the exhaust then it is likely condensation.skyblue1969 said:The leak isn't inside the car it's coming from underneath by the exhaust
If you mean on the end of this exhaust, i.e. dripping out the exhaust then this is perfectly normal, I've seen it plenty of times but from under the passenger? may be condensation.skyblue1969 said:The leak isn't inside the car it's coming from underneath by the exhaust
