1 - 10 of 10 Posts
Hey corsa people :D
Can somebody help me I want to put led's in my interior lights but I'm worried in case I break them when change them
Does the dome light just pop out and back on?
Should tell you in the manual.
Hi Fsamp
I changed my interior bulbs to Xenon Style ones, so they're whiter, and the front middle one to LED.
They're pretty easy to do, they do just pop out if you use a long screwdriver. Be careful as the material around them are very soft and fragile :D
I've managed to get the boot light out and done that
But still worried about the interior light :/
Google change corsa d interior light. That is how I got the tutorial.
Newer corsa DS have the same lights as the e.
I followed this guide.
http://www.vxronline.co.uk/forum/showthread.php?160132-How-To-Chav-your-corsa-for-a-tenner-(interior-reading-courtesy-lights)
You will need two T10 LED bulbs and one 42mm festoon led bulb for the interiour. The boot Bulb is a T10 also incase you want to swap that aswell. Ebay is the cheapest, my advice would be to search and refine lowest to highest price and make sure the location is in the uk. They should arrive quite quickly.
the size of the festoon does not really matter much a 38mm can fit you would just need to bend the terminals at each side.
You do not need them to be error free as they are not recognised by the Canbus system.
http://www.corsaeforums.co.uk/viewtopic.php?f=10&t=219&hilit=joeboy&start=10
Pics of mine installed.
1 - 10 of 10 Posts
