1 - 7 of 7 Posts
Hello guys, Ive got corsa 1.2ecotec 2016 and it wont start, it just cranks. Diag shows Map sensor performance and on live date while cranking it shows flat 0 kpa all the time.
Tried replacing sensor nothing, checked wires it power goes there and other wires good as well.
What might cause that there is no pressure in the intake or what should be the next thing to check.
Assuming the new sensor is ok and doesn't have the same fault,it looks likely a wiring issue to the sensor,continuity checks on the other 2 wires (signal and low reference) next i reckon.
1 - 7 of 7 Posts
