1 - 5 of 5 Posts
Hi, has anyone had a problem If you pull away quick and Rev the engine hard then change into second gear the gearbox makes a noise like the clutch isn't all the way down. Just wondered if a one else has had this problem and do you think I should mention the dealer as my car goes in on Wednesday to be fixed for something else.
Are you sure the clutch is down?
Probably driver error, as you state it is when you rev hard.
Not had any issues with my 6 speed box which is very smooth and doesn't even complain when quick changing/high revving during 0-60 tests.
1 - 5 of 5 Posts
