1 - 8 of 8 Posts
Just tip for anyone with annoying rattle with any bass from music in speaker area of door card. I just used some 1 or 2 mm thick back rubber and put it in a few places alone the bottom of door between card and metal. Completely out of site and completely stopped rattles without vx monkeys ripping car to bits.
Used small amount off force to make gap between card and door then put rubber in and released. Didn't remove card. Guess it's a loose fitting that just needs pulling on slightly to stop rattle.
I've tried to make a gap between bottom of door and door card but it won't budge so I'm going to stick some foam draught exluder strips inside the door pocket and see if it absorbs the vibration coming from the speaker grille
Another place is in door pocket between outer card and pocket. On the slanted part. Get the gap open and put some samples thin rubber in. Honestly worth trying few places. Can't see it and easy to remove but do eventually find the required place.
1 - 8 of 8 Posts
