1 - 7 of 7 Posts
rear view mirror is a bit loose took it back to vx and they said there all like it and it maybe a design fault anyone else had this issue
Nor mine. Is yours the standard mirror or the powered self dimming one?
Vauxhall mirrors are not bonded/glued to ththe screen like old Ford ones which used to always work loose and fall off, there is a plastic mount base on the screen that the interior mirror base slides up and a metal clip pings out to lock it in place so it's not loose. Definitely sounds like an issue.
They said they changed it but it's still the same.it's the block attached to the screen that's moving....going to get back onto vx and sort it
1 - 7 of 7 Posts
