1 - 20 of 20 Posts
been looking for a turbo decal for a few months. managed to find a supplier of eBay. I know its not every bodies states but I think it finishes the car. what do you think !!!!
Automotive tail & brake light Vehicle Automotive lighting Hood Car
anthony said:
joeboy said:
Anyone got any idea how to remove this part of the car?
it would still leave an indent in the body work
I understand it would leave an indent, I am just curious how it goes on and off. I am guessing it just clips on and off but don't fancy risking it.
It likely provides some structural integrity to the car, wouldn't recommend removing it.
Discussion Starter · #11 ·
tynamic said:
i want one for my car :D where did u find it? How much did it cost?
they cost me £4 for 4, can be done in most colours.
Discussion Starter · #13 ·
skyblue1969 said:
Do you have a link for them jaysen?
I have 2 spare white which I can send you for £3.50 which includes sign for delivery.
the best way is to order through me with the colour you need and I will sort out the order and post direct. the guy off eBay did them as a special order.
Discussion Starter · #15 ·
good luck fitting the decals you found on eBay SIZE 200MM LENGHT X 38MM HEIGHT do your home work 1st !!!!
20cm by 3cm is perfectly fine for a decal. If anything it's the same as the ones you have.
The ones jaysen has look more like 5cm rather than 20cm....can't see that fit on the small black fairing at the rear window
Discussion Starter · #18 ·
the measurement of my turbo decal is. 8mm by 55mm. which I think compliments the car perfectly. there is room for slightly larger. I also think this design fits the car.
Yea, but I was just stating that 20cm by 3cm is fine for a decal, rather than being too small for one as suggested.
I guess that decal is meant to be for the rear or maybe a window, rather than that small slot.
Discussion Starter · #20 ·
The turbo decal is an ideal place where its sits. people would think its a factory fit. maybe VX might catch on lol. I think if you go any bigger else where on the car its going to look a bit boy racer style. the other bits I've added is a top tint to screen. window wind deflectors. and darkened the rear glass. on my factory options I added bio Zeon's and a panoramic tilt and slide sunroof. the last mod I will do is 18 "alloys when the warranty runs out.
1 - 20 of 20 Posts
