Hard to steer after manouvering
Ironica
Post by Ironica » Wed Feb 21, 2018 7:29 pm
Hi all, today I was parallel parking when the wheel became hard to steer. The problem disappeared after moving in normal speed but appeared again when manouvering slowly. Have anyway experienced something like this before? Thanks
Re: Hard to steer after manouvering
Post by Susan44 » Wed Feb 21, 2018 10:10 pm
Power steering is not working. Take it to your dealer urgently. Hopefully the fuse.
Klesmy
Post by Klesmy » Thu Feb 22, 2018 12:15 am
Could be power steering pump or the belt driving it slipping either way it’s back to dealer ASAP
MY15 1.4 na Red Sting. Team Hekos fitted
Post by TheGeorge » Thu Feb 22, 2018 9:21 am
The operating manual stated something along the lines that if you make lots of low speed maneuvers, especially in city mode, it can overheat the steering motor. To protect itself, the power steering then goes into a reduced assistance mode until it cools down.
If it doesn't 'cure' itself in 30 mins or so, then is not overheating, and needs immediate servicing, as mentioned above.
Post by Susan44 » Thu Feb 22, 2018 9:47 am
Not in a Corsa. Totally electric in the column.
Post by FirestoneDK » Thu Feb 22, 2018 5:25 pm
Modern cars, including the Corsa, haves speed dependent power steering, maybe this is what is failing somehow?
Lusamoel
Post by Lusamoel » Sun Mar 04, 2018 12:45 pm
Theres nothing wrong with it. Its designed to go still as for over heating. The reason i know this as it happened to me loads of times. As im a driving instructor theres loads of low speed steering going on. When i took it back to the vauxhall garage after multiple time of it going stiff. They phoned head office tech and they said, if it was bought new as a instructors car, they usually upgrade something or put the values up on the limits. So wouldnt happen so much. Its from overheating and they couldnt do anything about it at the time. But it does free it self up after a few mins.
