No sound on any audio input!
Pargetev
Post by Pargetev » Mon Jun 06, 2016 5:26 pm
Hi all,
Got in my Corsa excite today to go to work... And have no sound from the intellilink system. Assumed it was my iPod but nothing from DAB, normal radio or from my phone either (therefore no calls).
Rang onstar and that worked so definitely not my speakers.
Has there been an update or anything that might have caused this? It's very frustrating!
Cheers!
Jarviser
Re: No sound on any audio input!
Post by Jarviser » Mon Jun 06, 2016 6:01 pm
It will probably work again if you lock the car and ensure the last red light (brake symbol) goes off after 30 sec approx.
All intellilink crap bugs usually go away after the car's had a sleep. Let us know if it recovered.
I have also discovered a reset to factory option in Settings/ Radio Settings that may help but it does lose all presets and BT pairings.
Pargetev
Post by Pargetev » Mon Jun 06, 2016 6:27 pm
Yeah I did hope that when I came home from work it would have magically fixed but still nothing. Was going to do a reset but haven't yet - may try tomorrow.
Still hoping it somehow fixes itself by tomorrow (my onstar did when that broke) but I foresee a trip to the dealer...
Andreal93
Post by Andreal93 » Sat Jun 25, 2016 9:12 pm
Did you manage to get this fixed? If so what was the solution? Ive had exactly the same problem. My onstar is working fine so speakers okay but no other audio
Kaw123
Post by Kaw123 » Sun Jun 26, 2016 11:10 am
I had the same experience on my 1.4T. I disconnected the battery for about 10 minutes which sorted the problem.
TBG01
Post by TBG01 » Tue Jul 19, 2016 1:59 pm
I'm also having this same exact problem. Did you find a solution?
I attempted to disconnect the battery but there appears to be something else on top of it not making easy access to the terminals.
Kaw123
Post by Kaw123 » Tue Jul 19, 2016 5:46 pm
You only need to disconnect the negative (black cable) terminal.
IonaCorsa
Post by IonaCorsa » Wed Nov 23, 2016 10:30 pm
I had my brand new Corsa e for just over a week when the audio stopped working. It cam back briefly for a few days and has now gone completely. I was advised that this fault may not be under warranty, is this correct?
Jarviser
Post by Jarviser » Fri Nov 25, 2016 10:19 am
I most certainly is a warranty item. I had my entire R3 intellilink replaced under warranty. Unfortunately the new one was identical in every respect.
If yours has the volume knob centre bottom it is a R4 and they sometimes self-update over the air. If it does not right itself after an overnight shut down with doors locked you can either try disconnecting battery neg terminal for 30 minutes or take it in for warranty fix.
Sare1976
Post by Sare1976 » Fri Dec 02, 2016 7:18 pm
Hi all, I know nothing of cars but my son has a new corsa limited edition, has no audio not even on his indicators, Vauxhall haven't got a clue, and he can't call onstar as has no sound, anyone got an idea what it could be? Tia
