"Service ESC". All power and control lost. non-start
danmurphy93
Post by danmurphy93 » Sat Jan 14, 2017 9:43 am
Hello
I am the owner of a 2015 Corsa 1.4 SRI Ecoflex which is displaying a message saying "Service ESC". I was turning a corner and the Stability Control symbol lit up on the dashboard and i lost complete control of my steering which nearly directed me into oncoming traffic. I applied the brakes and struggled to get the wheels to turn to the direction i wanted to go (to pull over on the side of the road). As I pulled over, the car cut out completely and a very strong smell of burning came into the car. I was unable to start the car again and the same message continues to show on the screen. Is anybody able to advise on what may have happened and whether this is covered under Vauxhall's Warranty?
Many Thanks
Daniel Murphy
Moog70
Re: "Service ESC". All power and control lost. non-start
Post by Moog70 » Sat Jan 14, 2017 10:16 am
It will be a warranty claim. Get them to recover it via the AA and tell them that it's too dangerous to drive. If they argue about it, call Vauxhall Assistance (AA) yourself, and get them to take it straight to dealer. Until they strip it down, you can only speculate as to what has happened, and it could be one of many things. Based on what you have described, my first thoughts would be that the module itself has shorted and burned out.
Johny555
Post by Johny555 » Sat Jan 14, 2017 10:53 am
Sounds bad mate,I would have shittttttt my self,got me worried about mine now,,I would think Vauxhall will sort it out,the car nearly killed you,!! Let us know how you get on,
QUAKERFARM
Post by QUAKERFARM » Sat Jan 14, 2017 11:45 am
I had a similar experience but without the smell. Vauxhall dealer was totally unhelpful, advised me to drive it if I wanted. Although under warranty (16 months old) the 1 year AA had ran out so if I felt the car was undriveable, I would have to get the car to the dealer myself! Spoke to my village garage mechanic who assisted me in getting the car to Thurlow Useless of Norwich.
The connector into one of the computer modules was loose causing loss of power steering and the ESC fault. Try pushing in all of the obvious connectors.
srihaggis
Post by srihaggis » Sat Jan 14, 2017 7:50 pm
There is a recall for loss of steering, if you look on the Government website for car recalls it's listed for Corsa E, chassis no's x to x.
MY16 1.4 Auto Energy 5 door Persian Blue, OnStar & Intellilink 4.0.
srihaggis
Post by srihaggis » Sat Jan 14, 2017 7:53 pm
Vehicle Details
Reference : R/2015/172
Manufacturer Ref : 15-C-077
Make: VAUXHALL
Model : Adam & Corsa E
Launch Date : 28/08/2015
Numbers Involved : 8883
Build Start Date : 23/06/2015
Build End Date : 29/07/2015
Recall Details
Concern : LOSS OF STEERING CONTROL
Description : The gears within the steering rack may not have been manufactured to the correct specification which may allow them to crack over a period of time. Prolonged use could cause loss of steering control.
Remedial Action : On affected vehicles, replace steering gear assembly
Vehicle Id : F6093210 to F6107950
F6091697 to F6107772
F4280638 to G4000196
Vehicle Details
Make: VAUXHALL
Recall Details
Vehicle Details
Reference : R/2015/234
Manufacturer Ref : 15-C-101
Make: VAUXHALL
Launch Date : 04/12/2015
Numbers Involved : 421
Build Start Date : 30/06/2014
Build End Date : 28/09/2015
Recall Details
Concern : LOSS OF STABILITY
Description : The connection between the steering knuckle and the lower control arm may not be assembled correctly. If this condition is evident the connection could become insecure. The event can happen suddenly and unexpectedly in which case the vehicle is no longer controllable.
Remedial Action : Recall the vehicles that are likely to be affected and inspect the connection between the steering knuckle and the lower control arm on both sides of the vehicle. Where necessary the connection will be reassembled correctly.
Vehicle Id : f6090776 to G6005712
E6090776 to G6005712
Johny555
Post by Johny555 » Sat Jan 14, 2017 7:57 pm
Were do you find the build number plz?
srihaggis
Post by srihaggis » Sat Jan 14, 2017 11:31 pm
Not sure, but this could be another useful source if you know your VIN: https://my.gm.com/recalls
Darren_SRi_2016
Post by Darren_SRi_2016 » Tue Jun 04, 2019 10:55 am
My corsa has suddenly been throwing this up on its dash. I did a OBD check and no faults have been found. I don’t lose power or steering, lose the Rev counter and temp gauge. When I take the key out, open the drive so the ignition goes properly off, lock the doors for a minute, unlock them and start the engine, the TC light has gone off and all gauges are back to normal
2016 66 plate Corsa SRi ECOflex 1.4n/a 5dr in silver 8-)
Jammers
Post by Jammers » Wed Jun 05, 2019 8:22 pm
This happened to me - Vauxhall did a software upgrade under warranty.
