My 2015 Vauxhall corsa developed a misfire
Johny555
Re: My 2015 Vauxhall corsa developed a misfire
Post by Johny555 » Mon Jun 19, 2017 4:25 pm
That's good to know,cheers,
Clare007
Post by Clare007 » Thu Sep 12, 2019 11:27 pm
Thanks to everyones advice as my 1.4 Sxi has started doing this and no codes showing
Klesmy
Post by Klesmy » Fri Sep 13, 2019 6:24 am
I’ve just fitted another pack to my 15 plate 1.4. First one failed under warranty and the last one failed last month
MY15 1.4 na 5 Door Red Sting.
Paulec
Post by Paulec » Sat Sep 14, 2019 3:57 pm
My 2015 corsa 1.4 just started to develop a slight misfire. It was serviced in April. and had new spark plugs. So I would think it stands a good chance of it being the coil pack. Been looking at different makes . HAAS or Delphi. Delphi got better reviews so looking at buying them. any ideas of which make would be best .
Klesmy
Post by Klesmy » Sat Sep 14, 2019 7:12 pm
Just a heads up. Delphi make the genuine GM part. I’m trying a haas one as already gone through two genuine ones in 5 years
Paulec
Post by Paulec » Sat Nov 21, 2020 4:42 pm
As anybody tried repairing a coil pack.I've seen coil pack repair kits on eBay.and the reviews seem to be good .
chemistman
Post by chemistman » Tue Nov 24, 2020 3:05 pm
Its a 20 minute job. Just disconnect the end plug (there is a small slider that locks the plug in place that needs to be moved first), undo the bolts holding the coil pack in place and pull it out (two bolts of the correct size screwed into the securing holes in the coil pack will help to give you the pull). Examine the holes where the plugs are screwed into for corrosion and clean if necessary. Reverse the procedure to fit the new one.
Paulec
Post by Paulec » Tue Nov 24, 2020 3:41 pm
Yes that is the way to replace or check the coil pack . But its not what the question was above.
chemistman
Post by chemistman » Wed Nov 25, 2020 2:42 pm
Oops! Sorry for the misreading of the question. Repair kits are OK if the fault is in the spring or the shielding but if it's internal then you've wasted your money.
