Air con / air circulation and rear windscreen demister
HaiderAliCorsa2015
Post by HaiderAliCorsa2015 » Sun May 27, 2018 1:02 pm
Hi guys, got an issue with my Corsa E 2015 Ltd Edition 1.4. For some reason the air con, air circulation and rear windscreen demister have stopped working. Blower works fine. Checked fuse 18 and that was fine for air con. They do not come on at all even if i press them and the light doesn't come on either. Any ideas? Was someone else who had the same issue online but he didn't write a fix. Thank you
Scottliam81
Re: Air con / air circulation and rear windscreen demister
Post by Scottliam81 » Sat Nov 21, 2020 11:07 am
Did you ever fix this problem as I have the same problem with my car ??
