Corsa se 1.4 auto 15 plate
Bazzamer
Post by Bazzamer » Tue Nov 27, 2018 9:15 am
Hi, Everytime i unlock car the head lights come on, have turned off auto lights, but next time i unlock the car they come back on and drains battery as i dont use car much, short journeys.
Another small fault i have is intermittent, every so often i get a noise like from the area around the washer pump, its like the pump comes on for one second then off, its doing my head in as no water comes out, if it is this. It works fine, but i thought something may have fallen onto pump moter earthing it out but cant see anything, and every time you go to show someone it dont do it. Its below battery area, only with engine running.
Lastly has anyone had a thought of using the front camera as a dash cam, as it seems a bit of a waste it just picks up road signs, dont know if it Is possible, as if it had a recorder it could be kept in glove box, out of sight. Its only an idea i had, as i want the camera hidden and the recording device not with the camera, any advise on anything would be appreciated.
Many Thanks
Bazzamer
Bazzamer
Re: Corsa se 1.4 auto 15 plate
Post by Bazzamer » Tue Oct 08, 2019 10:32 am
Update
The sound is coming from either, the fuse box or under it, just wondering if it could be a relay chattering, but would think if it was it would burn contacts out in no time. A display came up engine speed has been reduced, thought i could get home but broke down loosing everything. AA came cleared code and followed me home, but it came on again. Code is P0697 that is 5volt reference voltage circuit C sensor open. A mechanic put contact paste on connections throttle peddle, and Mas sensor, so far car has been ok. But i have still got this noise from either fusebox or under it, could this be the fault or connected to it, like buzz for about 3 seconds, then off for about 2secs then on again, took off fuse box cover off, but cant feel any buzz from a relay. Just wondered if anyone has any ideas, or do i just keep running it till it breaks down with a permanent fault. Trouble is lost all confidence in car, as no fault present, each time i drive it am expecting it to fail, done about 100 miles since happened, will try anything to solve it, but how can i find a daukt that is not there, many thanks to all.
