1.4 corsa overheating and losing water
joeboy
Post by joeboy » Sat Sep 19, 2020 6:38 pm
Hopefully you guys can help me out.
Today my 64 plate 1.4 Corsa E temperature gauge went from 4 bars as it usually sits to all bars and started making a beeping sound.
I pulled over and had a look and my coolant was a little low but nothing major.
I restarted the car after about 2 minutes and the temp went back to 4 bars.
I drove for about 10 miles and everything was fine.
On the way back home as soon as i got in my drive it did the same thing with the high temp and sound.
I looked under the drivers side of the car and can see a small bit of water running down onto the sump.
Anyone any ideas?
I am booked in for a service on thursday the 24th.
esdls
Re: 1.4 corsa overheating and losing water
Post by esdls » Sun Sep 20, 2020 8:38 am
Its difficult to be sure but it looks like the fluid may be coming from the area around the water pump maybe have a good look and feel around the water pump while the engine is off of course and no one can start it
Marksparks
Post by Marksparks » Wed Sep 23, 2020 7:05 pm
wouldn't be uncommon for waterpump/gasket failure, mine got changed after two years under warranty ,my garage picked it up on a service, and just did it.
joeboy
Post by joeboy » Sun Oct 04, 2020 9:15 pm
New water pump fitted and its running like a dream again.
