Alternator/ Battery charging
Bigjkelly96
Post by Bigjkelly96 » Sun Nov 22, 2020 1:05 pm
Hi all,
Currently having issues with my alternator.
Replaced Battery and Alternator in the last 2 weeks
When i start car, voltage is 14.9
Then will either drop to 14 volts, or drop to 12.3-12.5v
Im under the impression that the alternator should always be running over 14v to charge the battery.
Does anyone have this issue? Is it normal?
Nickosnose
Re: Alternator/ Battery charging
Post by Nickosnose » Mon Nov 23, 2020 9:05 am
If the battery is new and fully charged then the alternator will regulate it's output to the batterys needs...
are you running any load when it's in the 12v range?....if not then put on headlights,rear demister,heater blower on full and the output should increase to compensate...
