Vauxhall wheels
Wanted section. Corsa E / Vauxhall related items only please.
hendry
Re: Vauxhall wheels
Post by hendry » Tue Aug 18, 2015 2:14 pm
I had to get a puncture repair done last week on my NSF tyre, I don't think National replaced they valve as they normally would any time the tyre is dismounted from the rim because the rubber valve and valve cap match the other factory ones on the car, which if they have changed the valve is unusual because usually at the very least the cap is different. (its a deep cap on the Corsa so would look odd if they had used the same cap on a different style/length of valve.
2015 Corsa E 1.4i 90PS ecoFLEX 3 Door SRi
anthony
Re: Vauxhall wheels
Post by anthony » Tue Aug 18, 2015 11:08 pm
thats good to know and the kwik- fit article is useful even thou i would never go there
Jarviser
Re: Vauxhall wheels
Post by Jarviser » Wed Aug 19, 2015 11:19 pm
@hendry you say the valve stems are rubber. Are they flexible or stiff? I would expect them to be stiff but maybe rubber covered?
From what I am learning the longer TPMS caps are plastic to avoid corrosion with the stems, and have an O-ring unlike standard cheapo caps. I still haven't found an E to look at closely!
Jerry
Re: Vauxhall wheels
Post by Jerry » Thu Aug 20, 2015 11:14 am
Jarviser wrote:@hendry you say the valve stems are rubber. Are they flexible or stiff? I would expect them to be stiff but maybe rubber covered?
Here is a pic of the valve on my 16" wheel
Corsa SE 1.4T 5 Door Peppermint Green
Jarviser
Re: Vauxhall wheels
Post by Jarviser » Thu Aug 20, 2015 11:55 am
Thanks, thats clearly a bolted in solid stem. I just went to my dealer and I saw that very same valve on a Corsa E VXR, an Adam and a Zafira as well as a Corsa D in the car park. But the two other Corsa E in the showroom including an LE had floppy rubber stems. Obviously there is more than one type.
hendry
Re: Vauxhall wheels
Post by hendry » Thu Aug 20, 2015 7:45 pm
Jarviser wrote:Thanks, thats clearly a bolted in solid stem. I just went to my dealer and I saw that very same valve on a Corsa E VXR, an Adam and a Zafira as well as a Corsa D in the car park. But the two other Corsa E in the showroom including an LE had floppy rubber stems. Obviously there is more than one type.
Yeah they must have,mine has the black rubber ones.
Jarviser
Re: Vauxhall wheels
Post by Jarviser » Fri Oct 02, 2015 6:20 pm
Mine has the floppy rubber ones with long plastic caps.
Now a question. The dealer set my tyres at 42/44 psi which is way over any of the ranges. If I drop them to the comfort setting 31psi all round, will the TPMS system complain when I drive off?
skyblue1969
Re: Vauxhall wheels
Post by skyblue1969 » Fri Oct 02, 2015 8:11 pm
I have mine set at 35 f 34 r on light load setting and there fine
2015 Corsa E Limited Edition 1.4 Turbo Carbon Flash 3DR
Jarviser
Re: Vauxhall wheels
Post by Jarviser » Fri Oct 02, 2015 8:13 pm
skyblue1969 wrote:I have mine set at 35 f 34 r on light load setting and there fine
Thanks. Finally found a passage in paper manual said to turn off ignition when altering pressures.
LimeyUK
Re: Vauxhall wheels
Post by LimeyUK » Fri Oct 02, 2015 11:01 pm
I set mine to 38/36 and my dealer reset them all to 34 and made a point of telling me that they should be 34!!
I know you shouldn't go to the maximum, but the max on my tyres is 57 psi! I think 38/36 is perfectly fine!
Corsa E - Excite A/C with Black Alloys - 1.4 Turbo EcoFlex - Lime Green - 3 dr
Return to “Wanted”
