1.4na
ryanco
1.4na
Post by ryanco » Sat May 06, 2017 8:40 pm
Hello guys,
Wanting to get more of a roar and more sound out of my 1.4na, I know there's not an awful lot there but any ideas? somethjng that's not going to be too expensive.
15 plate LE.
MY15 Vauxhall Corsa E LE - White - 1.4
Appropriately named Colin
KingCraigx
Re: 1.4na
Post by KingCraigx » Sat May 06, 2017 10:26 pm
Ramair Cone Filter, around £25.. Sounds alright under acceleration.
Cobra Venom Corsa D backbox (Straight fit) - Sounds pretty good and only around £170ish new.
White Corsa 1.4 N/A LE w/ Sports Pack // Ramair Intake // Cobra Sports Exhaust // Full LED & HID Conversion
john002
Re: 1.4na
Post by john002 » Sun May 07, 2017 6:34 am
Hello guys,
15 plate LE.
Why bother it will still be a 1.4 Corsa. Buy a hot rod if you want some noise or a Lion they roar . :lol:
Re: 1.4na
Post by mattb_srivx » Sun May 07, 2017 4:37 pm
As above. Exhaust back box and a cone filter.
Bear in mind though that if it's under warranty still it'll void anything turbo/engine related.
Corsa SRi-VXLine 1.4T
Luke Corsa E
Re: 1.4na
Post by Luke Corsa E » Thu May 18, 2017 9:56 pm
I put a custom back box (3inch tail pipe) and a cone air filter on my 1.4 na and it sounds much better. Sounds much faster than it is. If your worried about voiding warranty some places will offer a lifetime warranty on all custom exhausts fitted and supplied by them so that could be something to consider.
Re: 1.4na
Post by mattb_srivx » Fri May 19, 2017 7:05 pm
It's not the warranty on the exhaust you've to worry about. IF the turbo was to fail they could claim it was due to the back pressure being altered from having a non-standard back box on there and they wouldn't pay out for it. Not something I'd personally want to risk!
Susan44
Re: 1.4na
Post by Susan44 » Fri May 19, 2017 11:24 pm
True for 1.4T but 1.4NA doesnt have a turbo. There are other engine problems that could happen but less likely.
Moody39
Re: 1.4na
Post by Moody39 » Mon Jun 12, 2017 11:06 pm
Anyone know if the corsa D badgeless grill would fit the corsa e? Wanting to completely get rid of the chrome and we badge the front?
Metallic Black 1.4na
Induction Cold Air Filter
Team Heko Wind Delfectors
Cobra Cat Back Exhaust System
KingCraigx
Re: 1.4na
Post by KingCraigx » Tue Jun 13, 2017 8:55 am
Nope, that doesnt fit.
iBlob
Re: 1.4na
Post by iBlob » Sat Dec 02, 2017 4:12 pm
I've fitted a cone filter to the car, had one lying around from my old car, so decided to fit it. Easy installation, took about 10 minutes. Unscrewed the airbox lid, loosened the jubilee clamp and pulled the lid and filter out. The airbox is held into rubber grommets, so a little wiggling, and it pops right out.
I did want to see if i could keep the airbox in, but my filter was raised too high so the bonnet wouldn't close, so it had to come out. Added a reducer so i could marry to cone filter to the maf sensor housing, and a couple of cable ties to keep it from bouncing around, while i fab up a bracket to use.
And this is the end result:
sounds more throaty now, which is all you are really going to gain from doing this, and i kept the cold air pipe from the front bumper in place, to allow cold air to flow straight to the filter, reducing heat soak where I can.
Hope this helps somewhat
2017 Corsa Energy A/C White - 1.4N/A / Cone Filter
Return to “Modifications”
