LED kits
Junx
LED kits
Post by Junx » Wed Nov 21, 2018 8:53 pm
Wan't to do all my rear lights LED and front indicators.
any advice or products?
Bogbrush
Re: LED kits
Post by Bogbrush » Wed Nov 28, 2018 5:20 pm
Not street legal, but Osram make some good products... although there is no guarantee they will work on your car even though the fitment is correct. There is plenty of info on this if you spend a good half hour with Mr Google.
2018 1.4T
bradleylawrence_
Re: LED kits
Post by bradleylawrence_ » Thu Nov 29, 2018 10:27 am
I've done my rear lights, they're wicked!
Front indicators are impossible, without cutting part of the plastic inside the headlight though.
For the rear of my car, I upgraded my number plate lights, rear/brake lights, rear indicators and reverse light - I also upgraded the side indicators, and front fogs.
The products are all from Autobeam, and look/work great! (www.autobeam.co.uk)
I also filmed a video, fitting the products, which can be found here -
Hope that helps, any other questions, please feel free to drop me a message!
2017 Corsa E 1.4i 90PS SRi
JJCB
Re: LED kits
Post by JJCB » Sun Dec 09, 2018 1:49 am
Which is the correct indicator unit for the e, autobeam seem to offer 2 different ones?
bradleylawrence_
Re: LED kits
Post by bradleylawrence_ » Sun Dec 09, 2018 3:03 pm
581 LED indicator unit is what you want for the rear indicators!
Bobbyt
Re: LED kits
Post by Bobbyt » Tue Dec 11, 2018 3:40 pm
Do you get any dash errors with the stop/tail bulbs?
Sent from my SM-G960U1 using Tapatalk
bradleylawrence_
Re: LED kits
Post by bradleylawrence_ » Fri Jan 04, 2019 4:02 pm
I do, yes, but clicking the indicator stalk in when it comes up quickly removes that. It's something that doesn't bother me personally, but understandably you may find it annoying.
Ecain11
Re: LED kits
Post by Ecain11 » Sun Sep 29, 2019 12:37 pm
Hi, I was wondering what errors you get on your dash from installing all the bulbs. Is it just an error for the brake lights. Cheers.
bradleylawrence_
Re: LED kits
Post by bradleylawrence_ » Sun Sep 29, 2019 9:37 pm
I get an error for brake lights and reverse light. But as I mentioned above, pressing the indicator stalk ‘OK’ button removes them.
H.sahota99
Re: LED kits
Post by H.sahota99 » Tue Oct 01, 2019 11:26 am
Do you know if these are very dazzling or not?
https://autobeam.co.uk/collections/vaux ... 5762519084
And is it simply plug it into the exisiting connector?
Return to “Modifications”
