Help with parts :/ do vxr parts fit my 1.4T?
MaGiikzZx
Post by MaGiikzZx » Mon Jan 07, 2019 9:08 pm
I have a 66 plate Corsa E 1.4T VX-Line Sri, I have had it remapped and I'm planning on putting an after market intercooler on along with an Induction kit, full exhaust system and body kit with bonnet vents. However I just need to know if Corsa E VXR parts will fit? My model?
1.4T [100] Sri Vx-line Stage 1 Remap.
Bruce_19
Re: Help with parts :/ do vxr parts fit my 1.4T?
Post by Bruce_19 » Tue Jan 08, 2019 10:47 am
What parts are you looking to fit?
Body parts I would say would probably be interchangeable like bumpers and skirts.
As for exhaust I'm unsure I know the new GSi has the same body kit are the VXR but has the 1.4T engine with the same style of exhaust but unsure if it has had to be redesigned for a smaller pipe or not.
2018 Black Edition (150) :D
MaGiikzZx
Post by MaGiikzZx » Tue Jan 08, 2019 1:27 pm
The parts I'm looking to fit are an induction kit and intercooler first then body parts last
M400WST
Post by M400WST » Tue Jan 08, 2019 2:11 pm
You'd be better off getting items designed for the 1.4T. Are you planning on getting it remapped again after fitting all these components? Generally it's advised to fit them first and then get it remapped.
The reason is simple is part for the VXR would have been designed specifically for the 1.6 Direct Injection Turbo engine that the VXR uses and will most not work in the expected way on a 1.4T.
2018 Vauxhall Corsa E 1.4T 100 Energy - Adapted by Opel Scanner
2011 Porsche Boxster 2.9 PDK
M400WST
Post by M400WST » Tue Jan 08, 2019 2:19 pm
Also taking to account the gains you would probably have got from 100BHP to what a stage one normally would be which is about 180BHP have you looked at brakes etc on car?
I know for a fact from 1.4T 100 doesn't stop as well as the 1.4 125 Astra Sport Tourer I had so if I was looking to remap i'd almost certainly want to upgrade the brakes and maybe the tyres too depending on what are fitted.
Maybe nice the car being able to go faster but you need it to stop too :)
Bruce_19
Post by Bruce_19 » Tue Jan 08, 2019 3:23 pm
Like M400WST has said probably best to look at parts for the car you have, their is no difference in engine from 100bhp to the 150bhp other than the factory map.
Also the tires and brakes are something normally overlooked as well as suspension.
If you do fit a VRX kit to your car or even just the rear defuser you could probably get a custom exhaust for the same price you would pay for a VXR one. Also on induction kit you are best getting an enclosed unit to save from heat soak from the engine if you are doing mainly start stop driving if not and want the noise I would go for a cone filter.
Other thing like suspension would be down to driving style and personal choice but if your making it go faster and stop better then handling is worth considering.
MaGiikzZx
Post by MaGiikzZx » Tue Jan 08, 2019 3:54 pm
Yes I'm planning to stage 3 remap after I fit all the parts but I can't find any for the 1.4T specifically, I have looked around but a lot of parts are vxr parts... Such as intercooler and induction, however the under the bonnet vxr and 1.4T look similar so parts should fit :/
M400WST
Post by M400WST » Tue Jan 08, 2019 4:15 pm
I would say you maybe best off speaking to one of the companies that fit or manufacture these items, they will be able to help and tell you whether they fit.
Companies like https://www.thorneymotorsport.co.uk/ may not list items but if you contact them they maybe able to help.
I did a quick google for an intercooler, one result said it was for a 1.4. Although the description mentions VXR, You have to remember a lot of these companies are small and will just copy and paste the description rather than removing the VXR bit.
You are right the 1.4 engine will be smaller than the 1.6 in the VXR so the space in the engine bay will be mean things will fit. In the case of the intercooler above if I was unsure because it said VXR in the description I would just pick up the phone and speak to them as they are the experts :)
Bogbrush
Post by Bogbrush » Tue Jan 08, 2019 4:16 pm
Great post - eminently sensible! The 150bhp 1.4T has different (larger diameter) brakes from the 100bhp so anyone (like me) considering a remap to circa 150bhp should always look at stopping power but make the mods inside factory parameters. There have been too many accidents caused by the well intentioned fitting powerful disks to the rear of their little Corsa because they look cool compared with drums. The problem is that over braking the rear can induce the car to spin in adverse weather
2018 1.4T
Bogbrush
Post by Bogbrush » Tue Jan 08, 2019 4:17 pm
Agreed. The brakes are larger on the factory 150bhp model compared with the 100bhp
2018 1.4T
Return to “Modifications”
