Rear interior LED
For all Corsa-E Modification chat
DeanCvij0
Rear interior LED
Post by DeanCvij0 » Wed Dec 11, 2019 6:24 pm
Hello!
I tried installing LED lights inside my corsa E and the front turned out all right no issues. But in the rear the LED bulbs just do not want to work they just flash once then all the interior lights turn off. What could be causing this issue?
CorsaVXLineMatt
Re: Rear interior LED
Post by CorsaVXLineMatt » Mon Dec 16, 2019 10:05 am
I had the same problem. I suspect the LEDs draw more power from the circuit.
In the end I bought some bright white halogens to go in the rear of mine which did the trick and don't look overly different in colour to the front LEDs.
Return to “Modifications”
