Engine Ticking/Rattle
Goldi98
Re: Engine Ticking/Rattle
Post by Goldi98 » Sun Feb 17, 2019 12:51 am
Hi guys I have the same issue with my 65 plate 1.2 Corsa e. I've had it since July last year and it ticks whenever it hits temperarure or whenever i use things like AC, de-mister, fan etc. In the morning sometimes I get a warning sign coming up saying "engine power reduced ." However There's no engine management light on the dash when I'm driving. The loud ticking sound comes from the right side of the engine and sounds as if the timing has gone on it or something. The ticking noise goes after I turn off the electrical components I mention ed above. I'm pretty confused as the car only done 20k and it's getting really annoying. Regarding to the "engine power reduced" sign I've plugged the computer on it and there were no faults whatsoever. If anyone has experienced anything like this and got it fixed please let me know thank you.
1stopel
Post by 1stopel » Thu Apr 18, 2019 3:11 pm
Hello.
Had ticking noise in engine part, minutes after starting it from cold. Before even reaching working temp.
Fixed under warranty and it was faulty "valve for exaust gases" something..... Can't technically explain. At the service they knew what was faulty because another 2 corsas with same issue.
Fault on turbo and non.....
mi68guel
Post by mi68guel » Sun Apr 28, 2019 11:02 pm
https://workshop-manuals.com/vauxhall/c ... mpartment/
Remedy:
In case of customer complaint install the following modified parts:
- Clip fuel evaporation hose to the bulkhead
(part-no.: 13352052/catalogue-no.: 8 24 024)
- Bracket of the fuel tank evaporation valve against the new version
with cut-out (part-no.: 55579903/catalogue-no.: 8 25 036)
Working Procedure:
1. Remove tank vent valve
- see working procedure "Replace tank vent valve
(not Z16LEL, Z16LER, A16LEL, A16LER ",
group "L Fuel and Exhaust System/Fuel System/
Tank Ventilation Valve", Service Instruction Corsa-D
(Document Number 01601230)
2. Replace tank vent valve bracket (Picture I, 1)
Note:
At the tank vent valve bracket is a cut-out (arrow) present.
Object Number: 27737362 Size: DEFAULT
3. Install tank vent valve
4. Replace tank vent hose clip at bulkhead (Picture II, arrow)
Object Number: 27737363 Size: DEFAULT
Spare-Parts: Part-No.: Catalogue-No.:
Tank vent valve bracket 55579903 8 25 036
Tank vent hose clip 13352052 8 24 024
Labour Times: TC: Hours:
U3 279 50 Tank Vent Valve Bracket 90 0.4
and Tank Vent Hose Clip
Replacement
The costs for this repair will be covered during warranty and policy.
For policy please refer to the Policy Guideline (WebPG/Kuugel).
The regular Warranty Procedure will apply.
FunctionalGroup: J - Engine
Complaint Group: 14 - Noises or Vibrations
Trouble Code: None
bearded_ed
Post by bearded_ed » Fri May 10, 2019 10:30 am
Remedy:
This is brilliant thank you, I am going to have a look at this for mine. I've done a fair few other bits an bobs maintenance wise now so I am hoping that this wouldn't be too difficult to sort.
2015 5DR Corsa 1.4 (90) SE + All the extras except R4.0 :(
Post by Rickardo » Fri May 10, 2019 12:37 pm
If you do attempt this post some pics
You can get the tank vent value bracket from Genuine Parts search for £7.34 delivered but not the vent hose clip
mi68guel
Post by mi68guel » Fri May 17, 2019 3:45 pm
Vent hose clip is available on eBay
https://www.ebay.es/usr/vauxhall-supers ... 7675.l2559
Jamescorsa16
Post by Jamescorsa16 » Fri Jun 07, 2019 8:24 pm
I have a 2016 corsa 1.0t ecoflex le and it has a ticking noise on idle I've not done a hole load of research but a lot of it says it is normal for the 3 pots to have a ticking noise due to it being unbalanced but it's still a bit worrying please let me know if you get it fixed and what you did
Nickosnose
Post by Nickosnose » Fri Jun 07, 2019 9:20 pm
The 1.0t has balancer shafts which is way it's so smooth...a light ticking on idle could just be the injectors..
Ours has a rattle/loud tap which starts just after the car is started after being left for an hour or so and is worst in warm weather..not the engine though,seems its in the transmission somewhere,only on idle so haven't decided what to do with it next..
Scooby8
Post by Scooby8 » Thu Nov 07, 2019 8:04 pm
Hi. Did anyone get this running-temperature ticking fixed either by a garage or by doing it themselves? N.
estupefacto_
Post by estupefacto_ » Thu Dec 05, 2019 12:07 am
I have a 1.4 gasoline and the same thing happens to me from the beginning. It is an annoying noise. Did you solve the problem?
