Annoying vibration when accelerating 1.4na help please
Dwyer
Post by Dwyer » Sun Feb 10, 2019 9:25 pm
I have an annoying vibration noise when accelerating. That is the best and only way I can explain what it sounds like. It only seems to happen when cold and when the engine starts to warm up if sounds normal. Can anyone point any light to this matter ?
It has had clutch and slave cylinder fitted last month could this be one of the reasons ?
TheGeorge
Re: Annoying vibration when accelerating 1.4na help please
Post by TheGeorge » Tue Feb 12, 2019 11:27 am
Had a small engine vibration a year back when cold, when the engine oil got diluted a bit with gasoline and other stuffs and level went too high due to short trips during the winter.
A cure would be a high speed run of 1.5-2 hours at 75 mph+. If the oil level is in between limits, then is something else.
Corsa E - 1.4T
MY 2016
Return to “Engine and Drivetrain”
