Major system failure
Jammers
Post by Jammers » Tue May 14, 2019 7:33 pm
Corsa Energy 1.4 N/a 16 reg
Started the car this evening, pushed the clutch down and turned the key and nothing happened for a second before it stated which was strange. Then received a multitude of warning messages - car theft deterrent system needs servicing, airbags need servicing, tyre pressure needs servicing and every warning light available remained on. Engine management light, airbag failure light, handbrake light even though it was off, fuel display only showed one bar, speedo and rev counter both not working.
Engine however working fine, Intellilink fine as was any electronics in car such as the heated seats, fan etc.
Booked in tomorrow. Any ideas?
Jammers
Re: Major system failure
Post by Jammers » Wed May 15, 2019 6:03 pm
So when they took it in they couldn't get it to do the things it were doing but it apparently partially matched a known issue so they upgraded software. We shall see.
Return to “Engine and Drivetrain”
