Engine replacement
spriggangoodjob
Engine replacement
Post by spriggangoodjob » Thu May 20, 2021 11:51 am
Hi all. I will be picking up a 2011 1.4 Corsa D 1.4 Think it's the SRi. I know this is a Corsa E site but hang on....
The engine is no good so I need to replace it.
Just wondered if you can tell me if the A14XER engine is the same as the B14XER.
Oviously I would be swapping all ancilleries from old engine to new but is the basic block and everything on the main engine the same to do the swap or will there be big differences and would it be right on the old ecu etc.
I am a qualified mechanic but not sure as to differences in the two engines.
Thanks in advance for any help Guys n Gals
