Opel Scanner to enable Trip Computer features
Audio, Navigation, Electronic
Re: Opel Scanner to enable Trip Computer features
Post by Rickardo » Tue Feb 18, 2020 1:33 pm
Gashead69 wrote:
Tue Feb 18, 2020 11:49 am
Hi, I've just bought a 2016 Corsa Energy 1.4 Turbo and would like to be able to access all the trip computer settings. The scanner in the link on the first post is now £140 but I've seen these on Ebay would anyone be able to tell me if they are the same.
Thanks in advance. Rachael
https://www.ebay.co.uk/itm/MAXIECU-OPEL ... 1438.l2649
Looks nothing like the original if you search for pics
Also the Gendan site doesn't list the E model so would check before you buy
Gashead69
Post by Gashead69 » Wed Feb 19, 2020 9:14 am
Thanks for taking the time to reply. i assumed the Gendan would work as the OP has a 68 plate and has successfully updated it.
john002
Post by john002 » Mon Mar 09, 2020 8:19 am
Scanner Price: only £ 140.00 !!!
That's a lot of money to be used once, perhaps cheaper to ask vx garage to do this scanning if they will
2015 Corsa E 1.4i 90PS ecoFLEX Excite (AC) , 3 Door, Shiny Rocks (Wifes)
2018 Golf SE, NAV 1:5 5 door Red (Mine )
DeanCvij0
Post by DeanCvij0 » Thu Mar 12, 2020 10:25 pm
Does this work on the red display also or is it only for the black and white display.
Doktor-X
Post by Doktor-X » Sat Mar 14, 2020 10:04 am
I also want to know is this works for red display i want to enable digital speedometar
M400WST
Post by M400WST » Mon Mar 16, 2020 11:33 am
Does not work with red display, only the black and white display's
2018 Vauxhall Corsa E 1.4T 100 Energy - Adapted by Opel Scanner
2011 Porsche Boxster 2.9 PDK
Opelcorsasweden
Post by Opelcorsasweden » Sat Mar 28, 2020 9:20 pm
Hi! What exactly do l need to programming The ipc in a Corsa - 17. Pro version or? //Mike
M400WST
Post by M400WST » Tue Mar 31, 2020 11:21 am
Mine is a 2018 Corsa and I used AutoScanner Opel CAN you do not need the Pro Version if you want to turn on digital speedo and fuel consumption etc... unless it's changed since I brought mine which was about 18 months ago.
The best way to get your answer is to go on their website and contact them with specifically what it is you are trying to achieve and they will tell you whether you need the standard version or Pro version
AdrianInsignia
Post by AdrianInsignia » Mon May 04, 2020 9:48 pm
agent-5 wrote:
Mon Apr 08, 2019 6:53 pm
Just a quick update. I now have the following menu options enabled on my car (in addition to the existing options) thanks to the Opel Scanner:
- Average Fuel Consumption
- Average Speed
- Battery Voltage
- Coolant Temp
- Instantaneous Consumption
- Remaining Distance (Fuel)
- Transmission Fluid Temp
- Elapsed Time Menu (count-up timer)
- Audible Overspeed Warning
- Fuel Used Menu
- Outside Temp
- Eco Menu
- Eco Index
There's a bunch of other options I've not enabled, but I'm going to try shortly. Why these features aren't enabled by default is a mystery to me!
hi m8 would you be able to do insignia if i paid you need do change the cluster theme? :) with the scanner can
Meddsy13
Post by Meddsy13 » Mon Jun 08, 2020 1:34 pm
- Average Speed
- Battery Voltage
- Coolant Temp
- Fuel Used Menu
- Outside Temp
- Eco Menu
- Eco Index
What software did you use to do this please?
The supplied software with the programmer?
