Can't find which fuse to use. I'm hard wiring nextbase dash cam which has parking mode requiring a permanent supply. fuse box behind glove box, number 31 should be the horn. It's empty. Need to know which fuse number I can use as an alternative, or which is the horn fuse. Corsa SE 2016. I know different models have varying amounts of fuses but the owners manual shows them all.
I used one of these in my last car (don't have a dash cam at the mo), but it includes an in line fuse. All I did was connect it to the rear of the 12V socket, or you can run wires direct to battery and stick an inline on/off switch somewhere convenient. Includes low voltage protection if you want to run the camera when vehicle is stationary / locked.
Did you ever find a permanent live fuse? I connected mine to one of the body control fuses- which is always live but don't do this because it means your headlights won't turn off😂 still looking for one, possibly thought of an alarm fuse but can't find one anywhere
Related Threads
Vauxhall Corsa E Forum
34.8K posts
6.6K members
Since 2014
