vauxhall intellilink Changes
Audio, Navigation, Electronic
CobbieUK
Post by CobbieUK » Sat Dec 02, 2017 11:02 pm
Good Evening All,
Been doing a bit of digging around the following Intellink system and managed to change a few things. Im wondering has anyone made major changes to there system or even installed other applications. Im trying to get a grasp of the system and how it works etc.......
Sosimple
Re: vauxhall intellilink Changes
Post by Sosimple » Sun Dec 03, 2017 9:28 am
There are 2 intellilink systems, 3.0 running windows, and 4.0 running linux.
You must specify which one you are talking.
For 3.0 some wallpaper changes has been made.
For 4.0 nothing.
What changes have you made, for which one?
CobbieUK
Post by CobbieUK » Sun Dec 03, 2017 12:36 pm
Sorry I have R3.0 I've changed the background and boot animations and also some of the icons but I'm wanting to make bigger changes.
Sosimple
Post by Sosimple » Sun Dec 03, 2017 1:52 pm
I don't think there are other changes that have been made in 3.0
There is a thread here if you haven't seen it, but how to change wallpaper is the only thing there..
Susan44
Post by Susan44 » Sun Dec 03, 2017 3:03 pm
That turd is as polished as you will ever get it now.
AAttar
Post by AAttar » Thu Dec 14, 2017 7:44 am
Can you supply us with step by step instructions?
Susan44
Post by Susan44 » Thu Dec 14, 2017 9:55 am
First use the forum search for the word "bricked". That should throw up the risks involved.
Secondly Win CE uses a mix of plain text files (the ones you have been able to alter and change background) and compiled object files. To modify the latter files would require the source code, which is unavailable, and so major modification is not available to the general public.
cmartino
Post by cmartino » Mon Feb 05, 2018 12:41 pm
That would be incorrect Susan, if you have a low ASM programming ability it is entirely possible. I’ve ran my own .NET 2.0 DLLs hooking onto the GMLan dll to interface with the canbus, you need to modify the registry to allow the cab installer to force the relevant net version on though.
Intellilink R4 retrofits:
http://intellilinkmods.co.uk/
thewhale
Post by thewhale » Mon Feb 05, 2018 9:52 pm
What have you done with your R3?
Corsa Design 1.4 3DR
www.samwhaley.com
Susan44
Post by Susan44 » Tue Feb 06, 2018 3:29 pm
Publish a full tutorial then clever clogs.
Return to “Electronics and In Car Entertainment”
