Multiple faults
Audio, Navigation, Electronic
oliverlewisfrost
Multiple faults
Post by oliverlewisfrost » Tue May 19, 2020 3:53 pm
Over the last 2 weeks my 15 plate Corsa E has had multiple faults.
Firstly, whenever I put the car in reverse, the infotainment screen brings up a message on a full black screen saying “service rear vision system” , (I don’t have any camera installed”.
Secondly, some of the steering wheel controls have stopped working. The volume up down & skip / answer phone section.
Lastly the ambient outside temperature on the infotainment screen no longer shows.
I’m fairly new to driving have had the car around a year.
I have no idea if all these small faults are all linked or just singular issues that have just arisen in the last few weeks.
Thanks for any help,
Ollie
Re: Multiple faults
Post by Rickardo » Wed May 20, 2020 11:57 am
Sounds like the Intellilink system needs flashing i.e. software update
You will have the older 3.0 version
VX will want to charge around £125-£150 for the privilege
Re: Multiple faults
Post by FirestoneDK » Wed May 20, 2020 1:44 pm
Try disconnecting the negative terminal of the battery for half an hour. This resets the CAN bus network and the radio entirely. Then take it from there, and see how the electronics behave.
Re: Multiple faults
Post by Moog70 » Wed May 20, 2020 6:33 pm
Or if you can't be bothered to wait, simply touch the VE+ to Negative leads together, which will do the same thing in a fraction of a second. (We have Range Rovers on the drive, and this is a common problem with CAN)
