Canbus
wheelchair
Re: Canbus
Post by wheelchair » Fri Jan 12, 2018 11:28 am
Hello Susan,
Quite a comprehensive report. But it might be selfish of me all I want to do is see where I am going in the dark !!
Regards
Barry
wheelchair
Re: Canbus
Post by wheelchair » Fri Jan 12, 2018 4:27 pm
Just fitted error free canbus bulb and get error warning 'CHECK REVERSE LAMP' is this just a nuisance thing or could it be harming the electrical system ?
Regards
Barry
Re: Canbus
Post by Susan44 » Sat Jan 13, 2018 3:51 pm
It will drive you mad but won't harm the car.
wheelchair
Re: Canbus
Post by wheelchair » Sat Jan 13, 2018 3:55 pm
Thanks for that.
Re: Canbus
Post by Susan44 » Sat Jan 13, 2018 4:19 pm
Not sure if a permanent canbus error message will prevent further more important errors displaying. Does it only display in reverse?
wheelchair
Re: Canbus
Post by wheelchair » Sat Jan 13, 2018 5:00 pm
Yes but never appeared the last twice I used reverse , weird .
Re: Canbus
Post by Moog70 » Sun Jan 14, 2018 10:09 am
Barry,
Go to Hellfrauds and buy this and see if it makes a difference - if it doesn't, take it back for a full refund.
http://www.halfords.com/motoring/bulbs- ... pgrade-kit
My guess is that this will put enough voltage back across the CAN to remove the error message once and for all. It worked on one of our Land Rovers (you only have to sneeze in their general direction for them to throw a fault code!)
wheelchair
Re: Canbus
Post by wheelchair » Sun Jan 14, 2018 7:28 pm
Thanks for the info.
Re: Canbus
Post by Nickosnose » Mon Jan 15, 2018 9:03 pm
It seems any bulb upgrade needs to have the extra resistor to keep the warning off ...interior lights don't though as they are not on the fail bulb system..
Return to “Introductions”
