Huawei P20 Android Auto
I've recently purchased a 17 plate Corsa E and will be looking at changing my phone soon. I currently have an iPhone 7 which works fine with Apple Play but I am thinking of getting a Huawei P20 (not the pro) and wondering does anybody have one and does it work fine with Android Auto?
Re: Huawei P20 Android Auto
It's probably the quality of the cable that you use to connect the phone to the car that you need to watch rather than the phone itself. It's best to use the cable that comes with the phone and not a pound shop cheapie.
1.4 Automatic SE
Hi. I have a p20 pro, I have a 67plate vxr and it works perfectly with Android connect, i found that it would only connect using the original USB cable for Google maps, I tried after market one 1st with no joy, did a Google search which solved my issue
Panoramic Tilt & slide sunroof
Bi-xenon headlights
Bi-xenon headlights
I have a p20 lite and it will not work with my 16 plate Corsa at all, tried using different cables and even tried it on my friends corsa.
[quote=Ants post_id=27794 time=1537400943 user_id=2817]
[/quote]
Have you downloaded and installed the android auto app on your phone? Also have you gone into the settings on the radio and enabled android auto?
[/quote]
Hi all,
I cannot connect my P20 Lite via USB on my 16 plate. Bluetooth is fine and I've got no problems on that. When I connect using the USB cable that came with the phone (with Android Auto running), the head unit doesn't even pick up a USB device (with Bluetooth off). I have tried different cables, adaptors and even on a different Corsa.... no luck. I've checked the settings on the head unit and all is good. Even tried my wife's Sony ZX and that linked with no problems, Google maps popped up on the display.
I've raised a help ticket with Vauxhall.... fingers crossed that they have a fix for this.
So whilst I only have a '15 plate and therefore no Android Auto. But with my Huawei Mate 10 Pro I also get an error message or nothing from the system when using USB. Maybe its just Huaweimarkyap73 wrote: ↑Fri Sep 28, 2018 9:31 pmHi all,
2015 5DR Corsa 1.4 (90) SE + All the extras except R4.0
On the R3 the error message is pretty normal for newer phones, since it wasn't designed with those in mind I'm guessing, My P20 Pro does it too.bearded_ed wrote: ↑Sat Sep 29, 2018 6:36 pmSo whilst I only have a '15 plate and therefore no Android Auto. But with my Huawei Mate 10 Pro I also get an error message or nothing from the system when using USB. Maybe its just Huawei![]()
Regarding the R4 error, is the phone in the standard "Charge Only" mode for USB (I.E. the little pop-up you get when you plug it in) because iirc that blocks any form of data from being sent over the cable and only power is allowed. my guess would be try the different transfer modes it gives you, if it still doesn't work, then its probably to do with Huawei's USB interface and not the car.markyap73 wrote: ↑Fri Sep 28, 2018 9:31 pmHi all,
if this is the case, im gonna hold off on the R4 Retrofit i was planning on doing and wait until i upgrade.
Ninja:
- A 2015 Corsa 1.2 LE in Carbon Flash with the R4 Retrofit
When plugged in via USB (I've purchased numerous cables and tried the cable that came with the phone) I get no option. I've manually changed this in Developers mode but still no luck.... Still cannot see the phone on the head unit.Regarding the R4 error, is the phone in the standard "Charge Only" mode for USB (I.E. the little pop-up you get when you plug it in) because iirc that blocks any form of data from being sent over the cable and only power is allowed. my guess would be try the different transfer modes it gives you, if it still doesn't work, then its probably to do with Huawei's USB interface and not the car.
I'm hoping that Vauxhall will back to me but I'm not holding my breath.
If I hear anything, I'll post the results up.
Please do mate!markyap73 wrote: ↑Sat Oct 13, 2018 8:35 amWhen plugged in via USB (I've purchased numerous cables and tried the cable that came with the phone) I get no option. I've manually changed this in Developers mode but still no luck.... Still cannot see the phone on the head unit.
Ninja:
