4th year service
stuntdouble
4th year service
Post by stuntdouble » Mon Jan 07, 2019 6:49 am
Hi
Anyone had their 4th year service?
was wondering whats involved and how much does it cost at a vauxhall dealer? Thanks
Mines a 2015 excite 1.0T
MY15 Excite 1.0T A/C S/S Flame Red
john002
Re: 4th year service
Post by john002 » Mon Jan 07, 2019 10:02 am
Kings Lynn VX
2015 Corsa E 1.4i 90PS ecoFLEX Excite (AC)
Just quoted: £328.
Join the VX club and save 25% off this price
MOT £ 27:43 extra work not included
Nickosnose
Post by Nickosnose » Mon Jan 07, 2019 11:32 am
just incase you don't go to a main dealer,VX now use Dexos1 oil for all petrol turbo engines so its best to make sure this is used...
Our 1.0t was done in November,all filters,plugs and with service club discount came to £280ish if i remember...
Bogbrush
Post by Bogbrush » Mon Jan 07, 2019 4:10 pm
The replacement parts are oil filter, engine oil (Dexos 2 ), air filter, cabin filter, spark plugs. You will be offered a brake fluid change as it should be replaced every 2 years. At the same time the brakes are checked for wear, the suspension checked for excess play and the electronic systems scanned for problems. Everything else is just a visual check. Your dealer will give you a quote if you phone them, and sometimes they do 'special deals'
2018 1.4T
stuntdouble
Post by stuntdouble » Mon Jan 07, 2019 4:16 pm
Thanks for the replys ,just wanted a ball park figure regarding price so very useful
Yes vx use a new generation dexo1 now in the small turbo engines confusingly it called dexos1 gen2 , just so you can confuse it with Dexos2 i presume.....
Post by mattb_srivx » Mon Jan 07, 2019 4:20 pm
It's definitely worth negotiating on price, usually they'll move a little if it means they get your money/business.
If your having the MOT done at the same time, make sure your not being charged full price for this. Most dealers do it for £27-30 when done at the same time as a service. Full price is around £54 if I remember correctly.
The 4th service is classed as a major service and will also involve changing things that so far, probably won't have been changed* unless your a high miles driver.
-Oil + oil filter
-Engine air filter*
-Cabin air filter
-Spark plugs x4*
-Brake fluid (they recommend every couple of years)
-Key fob battery
-Usual checks
You'll probably get all that done a lot cheaper at a good local independant garage. Just depends how important it is to you to have your service book main dealer stamped.
Corsa SRi-VXLine 1.4T
FirestoneDK
Post by FirestoneDK » Mon Jan 07, 2019 4:43 pm
-Oil + oil filter
-Engine air filter*
-Cabin air filter
-Spark plugs x4*
-Key fob battery
-Usual checks
4 spark plugs in a 3 cyl engine? :lol: :lol: :lol:
Klesmy
Post by Klesmy » Mon Jan 07, 2019 6:05 pm
Mine will not be going anywhere near main dealer (Wilsons in Scunthorpe) while I own the car. I got it from them and had problems with them from the start. The dealer stamp is not worth the extra money. At the end of the day it’s only a corsa!
MY15 1.4 na 5 Door Red Sting.
Post by mattb_srivx » Mon Jan 07, 2019 7:55 pm
-Oil + oil filter
-Engine air filter*
-Cabin air filter
-Spark plugs x4*
-Key fob battery
-Usual checks
Makes the £280 seem even more expensive now :lol:
Nickosnose
Post by Nickosnose » Tue Jan 08, 2019 8:37 am
Things like Brake fluid,Key battery,coolant are add ons at extra cost....only had ours done because we took a years extened warrenty..
Return to “Main Corsa E chat”
