Removing seats
The place to discuss everything else..
jrayf
Removing seats
Post by jrayf » Sun May 17, 2020 3:19 pm
I’ve got a 15 plate Corsa SE and want to remove passenger & driver seats to clean the carpet underneath. Does anyone know if it’s simple/easy to do? Will I set the airbags off?
Re: Removing seats
Post by Rickardo » Mon May 18, 2020 9:16 am
There are no airbags as such on the seats themselves but there are seat belt pretensioners so you need to disconnect the battery first
Move the seats as far forward as you can and if you look underneath you should she the connector for the pretensioner which you need to unclip
Once that is done it's a case of removing the bolts and the seats should come out
