Remove wax polish from black trim.
The place to discuss everything else..
john002
Post by john002 » Sat Mar 26, 2016 8:05 am
Whats the best way to remove wax polish from black trim.
I have tried back to black spray , this has not cleaned it off.
Cheers
skyblue1969
Re: Remove wax polish from black trim.
Post by skyblue1969 » Sat Mar 26, 2016 11:37 am
john002 wrote:Whats the best way to remove wax polish from black trim.
Cheers
Autoglym bumper and trim gel its what I use and its good stuff it doesn't contain any colour dyes just apply it to your rubber/vinyl/plastic trim and it restores them back to their original colour also it's water proof and can be put on door seals in the winter to stop them sticking when it freeze's
2015 Corsa E Limited Edition 1.4 Turbo Carbon Flash 3DR
Jarviser
Post by Jarviser » Sat Mar 26, 2016 3:21 pm
If you mean like Autoglym resin polish has left white streaks on the black trim then good luck!. I tried for 2 years to get it off completely, and you need something that dissolves carnauba wax and basically thats turpentine, or turps substitute. (Test a small area first as they say)
Then apply the above gels to merge the remnants.
john002
Post by john002 » Sun Mar 27, 2016 7:41 am
[quote="Jarviser"]If you mean like Autoglym resin polish has left white streaks on the black trim then good luck!. I tried for 2 years to get it off completely, and you need something that dissolves carnauba wax and basically thats turpentine, or turps substitute. (Test a small area first as they say)
Then apply the above gels to merge the remnants.[/quote
Will give this a try, cheers
peejay
Post by peejay » Wed Mar 30, 2016 11:27 am
Smooth peanut butter ! I'm an old timer and used it for years, water just beads off.
Return to “Off-Topic Chat”
