Engine juddering
nimro
Re: Engine juddering
Post by nimro » Tue Jul 17, 2018 1:40 pm
Just to chime in for anyone searching in the future, just had the same issue on my 65 plate 1.4 N/A.
VX replaced coil pack and spark plugs, under warranty (expires in Nov), 28k miles on the car. Usually these would be done in the 3rd service, get the feeling that maybe VX should move them to 2nd service...
Klesmy
Post by Klesmy » Tue Jul 17, 2018 7:43 pm
I assume your talking about plugs on 3rd service. A coil pack should last longer. I have checked I Wilson’s in Scunthorpe didn’t do my plugs at 3rd service.
Not returning there in the future anyway but will be getting them changed on next service.
MY15 1.4 na 5 Door Red Sting.
thewhale
Post by thewhale » Tue Jul 17, 2018 10:42 pm
1.4 NA here with same problem, coil pack and spark plugs replaced under warranty. 33k miles September 2015 car.
2019 Corsa Griffin 1.4 3DR
2015 Corsa Design 1.4 3DR
www.samwhaley.com
bearded_ed
Post by bearded_ed » Sat Oct 20, 2018 4:53 pm
ooo wow this sounds EXACTLY like the issue I am having!!!
The confusing thing is this has only happened a day after I did an oil change. I also am just over 30K miles, which similar to what you guys had too. How do I know for sure it's coil pack??
2015 5DR Corsa 1.4 (90) SE + All the extras except R4.0 :(
1.4autoenergy
Post by 1.4autoenergy » Thu Nov 29, 2018 1:51 pm
It was the coil pack for me as well
ncolvine
Post by ncolvine » Mon Apr 08, 2019 2:03 pm
I'm having exactly the same issue on my 66 plate now, so it seems to be similar to everyone else's in terms of age. Mileage wise it is also around 5k miles since it's last service, and is between its 2nd and 3rd. Very glad to hear that this comes under warranty though!!
bearded_ed
Post by bearded_ed » Fri May 10, 2019 10:33 am
Updating my experience.
I was just out of warranty (I'm a 15 plate - so an early car). It was my coil pack. Super, super easy sway. Did the spark plugs at the same time, £60 and half hour - problem solved.
Carlhusky8801
Post by Carlhusky8801 » Tue May 28, 2019 2:35 pm
Just having same problem again, coil pack replaced 31st may 2018 under warranty. Just gone again, 28 may 2019 and no warranty apparently 😡 picador Winchester quoting £310
sturn16
Post by sturn16 » Thu Aug 22, 2019 4:41 pm
I had the exact same experiences on a 16 plate 1.4 NA around 33k, 5 months out of warranty. Took it to Vauxhall who replaced the coil pack and Vauxhall warranty covered 60% of the cost, so not too bad.
Richard_D
Post by Richard_D » Thu Aug 22, 2019 7:36 pm
If you can do it yourself it's a lot cheaper.
Corsa Energy A/C 1.4 90ps Asteroid Grey
