New Corsa E 1.4 sri 75bhp 3dr/ Abrasive noise front wheels
Wheels, Tyres, Suspension, Chassis
paulJ
Re: New Corsa E 1.4 sri 75bhp 3dr/ Abrasive noise front whee
Post by paulJ » Sun Oct 23, 2016 12:24 am
Interesting post: let's think positive, this may be nothing more than a sticking caliper. Next time you come home,
gently feel the O/S and N/S discs and see if one is hotter than the other. Examine the outer pads (easy with alloy
wheels) and see if the N/S one is more worn. Note down what you find, inform your dealer: discs and pads are not
a particularly difficult task (did them on my C, took all of an hour), change them if in doubt. Here's hoping you get
this problem resolved in a satisfactory manner, kind of thing that could happen with any car.
Jarviser
Post by Jarviser » Sun Oct 23, 2016 9:40 am
they all make a rumbly scrapey noise on braking. It's just a matter of if it's excessive. Pay an indy mechanic a tenner for a second opinion.
Thebigm76
Post by Thebigm76 » Sun Oct 23, 2016 10:19 am
You should ask to test drive the same model of car and see if it sounds any different if there's no "road noise" then your car has a fault
Thebigm76
Post by Thebigm76 » Sat Oct 29, 2016 3:04 pm
Got mine booked in for next week to be looked at told them I wanted it mechanically checked not just a road test so fingers crossed
Post by Susan44 » Sat Oct 29, 2016 5:31 pm
Thebigm76 wrote:Got mine booked in for next week to be looked at told them I wanted it mechanically checked not just a road test so fingers crossed
They will charge you for new pads, I would bet on it.
Thebigm76
Post by Thebigm76 » Sat Oct 29, 2016 6:36 pm
After only 600 miles I won't be paying for anything
Pj46
Post by Pj46 » Mon Oct 31, 2016 4:07 pm
So yet another update. Today 31st October the car was back at Vauxhall Morecambe for a service process to establish once and or all ( or so I thought) what was causing this awful noise. Unfortunately no such luck. The service notes state Checked for grinding noise when driving, noise is still present. Carried out road test in similar vehicles and mileage but noise is not present on them. Carried out bulletin from Vauxhall but noise still present, technical case has now been set up.
So now will have to wait and see what happens. The brake system, pads,discs and callipers have been checked and are all in safe working order and are not the cause. This grinding noise appeared at just 300 miles and the car has now only covered 1400 miles and the noise has gradually increased throughout. So heres hoping this technical case will root out the cause once and for all.
Thebigm76
Post by Thebigm76 » Mon Oct 31, 2016 10:15 pm
Pj46 wrote:So yet another update. Today 31st October the car was back at Vauxhall Morecambe for a service process to establish once and or all ( or so I thought) what was causing this awful noise. Unfortunately no such luck. The service notes state Checked for grinding noise when driving, noise is still present. Carried out road test in similar vehicles and mileage but noise is not present on them. Carried out bulletin from Vauxhall but noise still present, technical case has now been set up.
Please keep us updated as I have the same problem as you and mine goes in on Wednesday
shazman
Re: New Corsa E 1.4 sri 75bhp 3dr/ Abrasive noise front wheels
Post by shazman » Sat Aug 11, 2018 8:01 pm
had mine in for same noise had baring changed alas still there
now got a clunk noisae wen reversin goin back monday grrhhhhh
other thing im gunna try swappin wheels left to right
1.4 corsa e 2017 LE
Post by Susan44 » Sun Aug 12, 2018 8:38 am
The TPMS will need relearning tool if you keep them swapped. Dont see what difference it will make
While the wheels are off check for rubbing disks, any dust shields and grit. Check free movement of pads etc. Roughness in the bearing too.
Return to “Wheels, Tyres, Suspension”
