Service esc
Cd7111
Service esc
Post by Cd7111 » Sun Feb 03, 2019 9:46 am
My car came up with a warning saying ‘service esc’ if you leaving it idling for a couple of minutes, car was serviced last week, then mechanic ran diagnostics and told me it was the rocker cover? So paid for that to be replaced and now all same lights have came on, traction control light and engine check light, any ideas?
paulJ
Re: Service esc
Post by paulJ » Sun Feb 03, 2019 11:51 pm
Good evening, it would appear from your post that you are nearly out of petrol. Allowing the tank to run low
usually causes problems, I never let my E drop below one LED segment. Best to refuel, check the oil level and
ensure plenty of % use available, reset any fault codes and see how things go. Let us know how you get on.
Re: Service esc
Post by FirestoneDK » Mon Feb 04, 2019 10:44 am
You should get your money back from that useless mechanic. If your engine is a 1.2 or 1.4 then it’s probably the coil pack and spark plugs that should get replaced. It’s a quite common issue, but to be sure you should hook up a scan tool to your car. If the error is related to misfires, then it’s for sure coil pack and plugs.
And just skip the non sense typed by Paul.
bearded_ed
Re: Service esc
Post by bearded_ed » Tue Feb 19, 2019 5:07 pm
I also had very similar issues, swapped coil pack and spark plugs.... all fixed. Did you get hesitant acceleration too?
BTW all of £60 ish down at Euro Car Parts and took 15 mins to do.
2015 5DR Corsa 1.4 (90) SE + All the extras except R4.0 :(
Daniellem87
Re: Service esc
Post by Daniellem87 » Fri Jun 14, 2019 2:07 pm
I have the exact same problem with my 2016 astra. Its jerking when still. Little loss of power. Engine and esc light come on. After driving go off.
Have been to garage had p0300 code. Misfire cylinder two.
Oil changed, spark plugs and a coil fitted. All seemed ok for half a day. Now all back on again? Its only done 27000. Losing the will... anyone get to bottom of this
Re: Service esc
Post by FirestoneDK » Fri Jun 14, 2019 10:07 pm
Do a compression test. They are prone to get cracked pistons due to LSPI, that's for both the 1.0T and the 1.4T
Daniellem87
Re: Service esc
Post by Daniellem87 » Sat Jun 15, 2019 8:00 am
Compression test has already been done with no issues. This sounds like its going to be a expensive job regardless now. If it is the pistons- is that a fix or new engine- how much does that cost?😱
