Squeaky clutch pedal
CorsaVXLineMatt
Post by CorsaVXLineMatt » Tue Oct 29, 2019 8:19 pm
My 2017 Corsa VX Line's clutch pedal started squeaking so took it to the dealer. Turned out to be the release spring had got dry. Was all sorted under warranty.
Has anyone else had this problem?
bones85
Re: Squeaky clutch pedal
Post by bones85 » Tue Oct 29, 2019 8:44 pm
Yeah
I've noticed that with my clutch pedal,
I noticed mine in traffic.
Mine is a vauxhall corsa e 16 plate
Seronix843
Post by Seronix843 » Tue Oct 29, 2019 10:26 pm
Mines squeaking but only when I lift my foot off the pedal. Is this the same issue you had? Because I thought a bit of WD40 might do the trick.
fieldcj
Post by fieldcj » Tue Oct 29, 2019 11:04 pm
Mine squeaks too when taking my foot off of it ... If anyone has an easy fix I'd be interested to know too
Sent from my CLT-L29 using Tapatalk
H.sahota99
Post by H.sahota99 » Wed Oct 30, 2019 1:50 pm
I have the same problem. Someone posted pictures of their return spring however mine has like a return cylinder that gets compressed or something.
Attempted to grease that but didn't have much luck.
Mines also only when releasing.
56 plate
bobtheslark
Post by bobtheslark » Thu Oct 31, 2019 8:02 pm
I've always sprayed the spring and pedal pivot with silicon oil on all my cars. You'll need to have the spray pipe attached to get in the space properly and up close. Always cover the pedals when doing this to make sure you don't make the pedals slippy.
Bobtheslark. Corsa E Excite a/c
1.4 turbo 6 speed > colour .. pepperdust
CorsaVXLineMatt
Post by CorsaVXLineMatt » Wed Nov 06, 2019 10:14 pm
Apparently Vauxhall have changed the design now so it won't happen again. Dealership said it was/is a common problem.
bones85
What obd reader would you recommend
Post by bones85 » Sat Nov 09, 2019 11:30 am
Looking for a obd reader
As many random things come up on my 3 year old car
