Fault code - P0301
CDAW
Fault code - P0301
Post by CDAW » Wed Oct 14, 2020 12:34 pm
Has anyone had experience with this fault code.
The car is idling rough (the rev counter is stable), pull off is rough and lack of power.
I have seen something about spark plugs and ignition coil - both are on order (due tomorrow).
Is there anything else that could be an issue?
Corsa Excite Ac Ecoflex 1.4L 3Dr (2015)
chemistman
Re: Fault code - P0301
Post by chemistman » Wed Oct 14, 2020 2:05 pm
Most likely coil pack / plugs. Whats the age/mileage of your car? Please come back to the forum if a new coil pack and plugs don't cure the problem.
CDAW
Post by CDAW » Wed Oct 14, 2020 3:24 pm
Mileage is around 29200 - most of it has been motorway driving
Post by Rickardo » Thu Oct 15, 2020 12:46 pm
P0301 is Engine Misfire Cylinder 1
It will be the spark plug probably corrosion
I had similar on mine with Cylinder 4 and when i took the spark plug out there was surface rust on it
As advised would put a new coil pack on as well
The issue is VX recommend changing spark plugs every 4 years which is too long in my book
CDAW
Post by CDAW » Thu Oct 15, 2020 3:56 pm
Plug 1 has better days. Replaced all 4 and ignition coil. All seems ok. Will see how the 56 mile journey to work goes tomorrow.
CDAW
Post by CDAW » Thu Oct 15, 2020 7:43 pm
Here's some pics
Corsa 1
Corsa 2
CDAW
Post by CDAW » Thu Oct 15, 2020 7:49 pm
Based on the rust showing on the spark plug, someone suggested I get a compression test done of the cylinder as there may be water getting in.
Any thoughts?
Post by Rickardo » Fri Oct 16, 2020 12:32 pm
tell tales signs are
Coolant level dropping
Continuious white smoke coming from Exhaust
White substance on underneath of oil cap
You should only do a compression test if engine is still running rough or is lacking power
If everything is fine then I would not worry
CDAW
Post by CDAW » Sun Oct 18, 2020 12:35 pm
No smoke, oil cap is fine and coolant levels are good.
The car seems to be running smotothly now - will see how my trip to work goes tomorrow.
john002
Post by john002 » Mon Oct 19, 2020 6:25 am
Any thoughts?
If the car is pressured washed is there a chance water has overflowed from top of bonnet/windscreen onto coil pack, just a thought.
