41 - 56 of 56 Posts
66 Plate
I did the:
  • Turn Off
  • Turn ON
  • Hold Power and Right Skip Button
It DID NOT work because I was on DAB Radio.
Make sure you're in FM Radio mode and not DAB
As soon as I tried it in FM Radio mode I heard static through the speakers.
I switch back to DAB and "Hey Presto!"
Hope this helps!
Thanks for that! I was doing this with DAB and no joy! Turned to FM and did it again and it worked a treat 👍
66 Plate I did the:
  • Turn Off
  • Turn ON
It DID NOT work because I was on DAB Radio. Make sure you're in FM Radio mode and not DAB As soon as I tried it in FM Radio mode I heard static through the speakers. I switch back to DAB and "Hey Presto!" Hope this helps!
The screen turns off as soon as I hold the power button.
66 Plate
I did the:
  • Turn Off
  • Turn ON
Hope this helps!
The unit turns off as soon as I touch the power button so there is no right skip button to hold!
Hi all,
I had the very same problem about half a year ago now so im not too sure i remember how it got fixed in all accuracy, but i took it to a dealership i bought it from and i was helped by one of the VX staff members, what he did to fix the problem was turn off the system competely by holding down the power button then switching it back on again then he held down the skip button right or left (sorry cant really remember) for around 10-15 secs, apparently it was a sort of hard reset and the music instantly started playing again from the radio. -Ben
This worked thank you
66 Plate
I did the:
  • Turn Off
  • Turn ON
Hope this helps!
A million thanks from me too! This also worked for my 2016 Opel Corsa-e (in the Netherlands).
Hi all,
Thank you so much - just found this after Googling when the same problem occurred suddenly and it’s fixed it instantly!
Hi all,
I've just been out to my 2016 corsa E and tried your remedy to reinstate the sound on my radio and bingo.What a relief, thank you
Hi guy, can anyone please help or advise me, my corsa 1.2 radio is not working but the aux does work, I try using the Bluetooth device that you plug in through the cig lighter to tune the channel that's not working either any suggestions. Have hold down the skip and on button to rest still nothing, can it be the fuse or I need a new radio, I heard it could be the tunner. It tunning but no sound at all or radio static sound. But I get sound from the aux any help would be appreciated thanks.
Hi all,
Got in my Corsa excite today to go to work... And have no sound from the intellilink system. Assumed it was my iPod but nothing from DAB, normal radio or from my phone either (therefore no calls).
Rang onstar and that worked so definitely not my speakers.
Has there been an update or anything that might have caused this? It's very frustrating!
Cheers!
Some really useful information below on how to reset. Worked for me just make sure you’re on FM not DAB when resetting
I thought it didn't work at first as well but, as Tre10tre10 mentions, you have to make sure the radio is on FM and not DAB. It worked for me and has been fine ever since....
Wishing you luck!
Hi all,
Ben you are a f'in legend. Thanks mate
Ben - genius - just did the same things and it worked. I have tried shit loads doing thi sand been driving around with no stero for 8 months before i read this. I have been to dealerships and a few other 'experts' and no joy. I had just accepted my fate and purchased a bluetooth speaker for my car. FFS!! It was as easy as you said:
1. Turn off power
2. Turn on and hold down on button whilst holding Shift Right button next to it.
EUREKA!!!!
Hi all,
Wow, just done that and problem solved, thank you.
41 - 56 of 56 Posts
